Thread: 06D ' phase barrier ' re & re
    Vancouver , Canada
    I have been playing with 06Ds for near 30 years and have yet to have to replace the ' phase barrier ' ( the plastic terminal isolator on the terminal block - part # 06DA503674 ) on one.
    I received a new rebuilt 06DM from Carrier last week, and when our forklift driver was moving it, toppled the thing over and it broke the phase barrier - the brass terminal studs appear unscathed, just the plastic is broken badly - my question, the brass nuts on the studs appear imbedded into the plastic to some degree - is there a special procedure or trick or special tool to re & re??
    The Carrier parts guy was no help and I don't want to screw things up.
    Thanks in advance - - -
    Dave Beauchesne CM
    Superheat and subcooling tell it all !
    Feb 2007
    Dallas, Tx.
    There should be nuts on the bottom side as well. Just watch the terminal studs while you turn the nuts to make sure that the studs don't rotate. The nuts shouldn't be recessed into the plastic. I think that there is also a screw in the middle that you will need to remove.
    mike
    Apr 2001
    Quote Originally Posted by freonguy View Post
    Dave Beauchesne CM
    Dave,
    Here's everything you wanted to know about 06D's but was afraid to ask:
    http://www.carlylecompressor.com/Fil...ver_LOWRES.pdf
    See Fig. 17 on Page #111.
    Jabs
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
