+ Reply to Thread
Results 1 to 16 of 16
Thread: NAVIEN COMBO 180 BOILER issues
    Jul 2003
    Rochester NY
    Ignition failure code on a newer unit natural gas correct pressures.
    Anyone else have issues with these units ?
    More info is needed.
    Jan 2015
    I saw a gentleman on linkin by the name of Chris Staley who is friends with I belive everyone that's works @ Navien. His list of specialties one being a Navien service specialist. He posted a long to some website I beleive to be his just by reading it and looking at the pics on the website (by the way I do believe it was some of the best Navien installs I have ever seen). What I'm getting @ is their is a place to email him questions or comments. Maybe try there. Here is the link I found
    http://cstaleyofregalincpics.page.tl/ Hope this will help you
    Jan 2015
    Bellevue, Washington, United States
    more info is needed. Most Tankless units I've serviced that were having problems were usually caused by installer error. Most common problem is undersized gas line.
    Jul 2003
    Rochester NY
    Hi guys thanks for the replys. It was 0 deg weather the week this unit had problems.
    It has a dedicated 3/4 black pipe gas line.
    The gas meter on the house is very very old and is getting replaced by the utility company.
    I had correct gas pressure of 3.5 inches.
    Its been running fine with warmer temps. The ventng is correct too with the intake pipe and vent pipe spacing correct.
    EXIT 16W www.wmtandson.com
    would help if you described the "issues"
    Quote Originally Posted by rob air View Post
    DON"T mess with the US
    I thought I had been there and done That.
    ITS ALL ABOUT LEARNIN!
    I thought it would be better by now
    "He who works with his hands is a laborer.
    He who works with his hands & his head is a craftsman.
    He who works with his hands, his head & his heart is an artist."
    ~St. Francis of Assisi
    VA
    You're painting with a very broad brush my friend.
    3/4" line means nothing without length.
    Are you a homeowner or tech?
    "The only true wisdom is in knowing you know nothing" Socrates
    Oct 2013
    Alberta Canada
    Had a ton of issues on the first gen, second gen and beyond were much better.
    Ignitor?
    flame sensor?
    could be lack of maintenance
    Quote Originally Posted by Linktorn View Post
    Dec 2006
    toronto, canada
    If you got 3.5" gas pressure on a Navien unit, you are having problem. Cause for inlet, 3.5" is not enough. For outlet, newer model should be negative because the inducer suck in the gas and air; for old model, you have to follow their instruction on how to set gas pressure, you cannot just measure the manifold pressure.
    Dec 2006
    toronto, canada
    Maybe you can try this one. http://us.navien.com/Content/Attache.../NCB/main.html
    This for newer model.
    Dec 2006
    toronto, canada
    Jul 2001
    Fairfield and NewHaven Counties in Commecticut
    The CH180 models will not work for more than a day when cold on propane. The NCB210 is fine.
    No way to fix the issue either.
    Quality and Value Service and Repair
  14. #14
    Feb 2014
    Connecticut
    I had a ch180 LP unit that we kept getting the same error. According to Navien they have had ongoing issues with the ch180. They ended up replacing it with a ch210 and there has not been anymore issues. Supposedly the ncb180 has no problems with Navien having changed to a negative pressure gas valve.
  15. #15
    Jul 2001
    Never heard of a good one yet
  16. #16
    Aug 2014
    Oxford, Massachusetts, United States
    What is your dynamic vs static pressure
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
