Results 1 to 9 of 9
    Atlanta, Ga
    Reversing a PAV with ridge vents
    Has anyone given thought on reversing a PAV if your house has ridge vents? This will eliminate the negative pressure in the home and even on hot days bring in "Cooler" air. Then the passive flow of the ridge vents will evacuate the air up thru the roof line. Thoughts?
    Joe
    Nov 2000
    Eastern PA
    Maybe if you state what a PAV is.......
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Powered Attic Ventilator.
    And no, thats generally going to be a bad idea. You're going to get hot dusty attic air forced down into the home.
    Lancaster PA
    As above. If running a PAV puts your house into a neg pressure, then running it as a intake will pressurize your home with hot humid unconditioned air.
    Ohio
    If your PAV pulls your house into a negative pressure, don't you have other issues to worry about?
    I need a new signature.....
    Atlanta, Ga
    Well, it was a thought....did not think it would fly, but had to ask....Have 2 PAV's in the attic disconnected, I guess they will stay that way....
    For Sale: 2 slightly used PAV's ....best offer...
    Tennessee
    ridge vent is a passive system, that's why it works the best.
    Madison, WI/Cape Coral, FL
    The solution is obvious. One sucks while the other blows. Called balanced ventilation. That was easy. Regards TB
    Huntsville,AL
    might help keep rain out of roof vents --
    BUT, might bring rain thru PAV --
    -- unless 'hat' of pav has large diam [ say, that of those of 1970s ] or has a 'skirt' around the outer edge of 'hat'
