    Apr 2008
    how to connect the peimeter duct in concrete slab to addition area?
    Hi everyone,
    I am working on a house addition project in chicago, IL area.
    The existing house has a perimeter loop duct in concrete slab. how do i extend the existing duct (actually, it's like a big PVC pipe in the concrete slab) to addition area?
    Or do you guys have any recommendation to heat and cool the additional space, it's about 300 sf. i am also thinking to install a mini-split heat pump if the duct connecting isn't possible.
    any comments will be appreciated!
    Mini split. The duct isn't sized to handle the addition.
    Apr 2008
    Alberta Canada
    call a contractor
    You should call a contractor to make sure the duct size and furnace size is compatible for the addition.
    Quote Originally Posted by GT2008 View Post
    Hi everyone,
    Do it right the first time.
    Chicagoland
    A mini split is a good choice for cooling but heat pumps and chicago winters dont mix! Consider a "through the wall" unit also called a PTAC with electric heat.
    Apr 2008
    Thanks for all you guys' comments.
    The contractor has verified the enough furnace capacity to handle addition space. The big issue is the duct connection to the addition.
    Does it have any problem when existing area runs forced air heat and the addition runs mini-split at the same time?
    thanks again!
    The furnace may be big enough, but the slab duct won't be.
