Results 1 to 13 of 29
    ohio
    HVACPro and XP please help!!!
    I have installed hvacpro on two computers that have xp running. The first is a dell using a usb to com port adapter and the other is a winbook that has a com port. Both computers I can use the com port for gx9100 and other programs but when I try to connect to a device through hvacpro with a cablepro I get an error that says com port in use by a dos application, then it will say do you want to reassign, it you say yes it cycles the same screens again. Is this a common problem how do I fix this. thanks in advance.
    Feb 2007
    I have connected with xp and not seen this error, are you sure nothing else is using the port when you tried?
    In your system properties:
    What is your com port setup as (com1, com2, etc)
    What version of HVACpro do you have?
    What cablepro do you have? (old one or new)
    ohio
    HVACPro is version 8.02 and my cablepro is old but it works fine with my toshiba with windows 98 installed.
    Jan 2005
    Quote Originally Posted by michael26 View Post
    I also have this setup and have no problems. I did however have a problem when comfortview was installed at the same time I was using hvacpro. Removed it from the startup menu and problem was gone. My kit is about 5 years old is pro-100 i think.
    "It's always controls"
    For USB support you will need to be at Rev 8.08 with the B patch.
    Check readme attached...
    SORRY>>>>>see attached.
    Mar 2006
    Is PMI loaded on this machine as well?
    May 2003
    Connecticut
    Where can this patch be found?
    ohio
    The winbook that I have has a built in comport and it has the same error. comport in use by a dos application
    ohio
    What is PMI?
    Melbourne,Aus
    Quote Originally Posted by skwsproul View Post
    Use the attached to stop the CView services taking control of the comm port.....
    net stop "ComfortVIEW GUIService"
    net stop "ComfortVIEW ActionService"
    net stop "ComfortVIEW ReportService"
    net stop "ComfortVIEW ObjectService"
    net stop "ComfortVIEW CommService"
    net stop "ComfortVIEW DDEService"
    net stop "SQL Anywhere - bsiv"
    Put it all into a batch file and call it what U want!!!!!
