Results 1 to 9 of 9
Thread: Sanding copper
    Spartanburg/Greenville South Carolina
    Lightbulb Sanding copper
    I know sandpaper works best but any kind of tool you can use in its place
    California
    the sell wire brushes that can sand the exterior and interior of copper pipes.
    SW Florida
    sandpaper and plumbers cloth are the worst as they leave grit. Scotchbrite pads or wire brushes are best
    Jan 2005
    Pennsylvania - Moved to Maryland
    I cut the plastic or wooden handle off the brush and chuck the remaining part into a drill. Makes cleaning the inside of fittings fast and easy...
    I came into this world with nothing, I still have most of it left....
    Jan 2005
    Veterans Home Yaphank, NY
    Smile
    When working on Copper I use "Copper-Brite" wipe it on, wipe off the schmootz.
    RAM Teaching Tomorrows Technicians Today.
    ky
    Quote Originally Posted by icehouse View Post
    I though Copper brite is Acid soluttion and corrosive right . What happen with excess ?
    Cincinnati, Oh
    "power douce" is a product you can pickup at supply houses here in ohio. It's a 1/4" chuck attached to a inside/outside brush, with a slidable head allowing you to change from inside to outside very quickly. Also having it on a drill speeds up the process ALOT.
    "Just get it done son."
    Dad adjusted
    West Valley City, UT
    Cincinnati, Oh
    http://www.johnstonesupply.com/101/t...duct_group=495
    looks like that only has a chuck on end. the white part slides down the chuck to let you switch between inside or outside.
    Dad adjusted
