Results 1 to 13 of 31
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    Digi-Cool & YJ's
    Here is my new Digi-Cool & YJ clamp on temp probe made by Weber.
    Works great! Check it out.
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    Very very nice,
    Did you send a picture to Doug?
    Could you show a picture of the wire at the head and how you feed it thought the clamp.
    It's a better set up then mine with a hand clamp. I'll try to get a picture soon.
    weber's Avatar
    I ran it through the clamp just like the original one, at the end I drilled a small hole to pull it through the clamp and then drilled the surface area to offset it and glued it in.
    What is your TESP?
    Central Kentucky
    Very cool weber!
    You finally found a used clamp eh?
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    weber's Avatar
    Quote Originally Posted by davidr View Post
    Very cool weber!
    Nope, I bought a brand new one.
    I couldnt find one, I looked on ebay and got tired of not finding any for the right price. Most of them were almost the same price as a new one and who knew if the clamp was really any good.
    So I went to the supply house and bought one. I used my old one to make the clamp, and replaced mine with the new one.
    What is your TESP?
    Not too shabby Weber.
    Did'nt have a Fluke or Fieldpiece sitting around at the time.
    But the velcro had to go.
    Took a Irwin Quick-Grip 2" clamp hollowed out the left side with a Dremel.
    Siliconed the probe in place and the wire in the hollow of the clamp to retain it from moving.
    See from the photo that you have the 2nd generation probe wire.
    FEN
    weber's Avatar
    Quote Originally Posted by the mojo View Post
    The copper barrell end, I like this one much better then the original one,
    What is your TESP?
    don't hate web, but am in the process of doing the same thing one of my co-workers was throwing away his old clamp because the wire had broke right at the end where it connects to the meter i was originally going to use my clamp and put the YJ sensor opposite of the FP original and double check every reading
    How long does it take to settle down and have a steady reading? The one I made takes abit to equalize the temp of the clamp.
    weber's Avatar
    Quote Originally Posted by Reeferman View Post
    The same or quicker then using the velcro strap.
    What is your TESP?
    clamping in itslef is faster than fooling around with 6 miles of velcro
    I fix mine when stuff like that happens.
    its broke right at the k-type connector. it would take more work than its worth to fix. so i am going to make what weber has made i started a couple weeks ago, but got side tracked.
