Results 1 to 8 of 8
    Oct 2007
    Refrigerant leak detector
    Whats a good electronic refrigerant leak detector thats not to expensive?
    define inexpensive
    South Carolina
    $1
    Western NC
    I got mine off Ebay. Its an Inficon TeK Mate. Works pretty well.
    I have only used it a few times. I prefer compressed nitrogen and soap bubbles. If you can't find it with nitro......you probably won't be able to find it with electronics.
    Jun 2007
    Round Rock
    I use the Infinicon as well. I paid $150 a few years ago. You can't get it within 10 ft. of a good R22 leak, it freaks out. Not as responsive to 410. It worked well with 134A. You have to replace the little sensor thing every 2 years or so. I think it costs $40.
    Charm City--the city that bleeds
    Quote Originally Posted by iraqveteran View Post
    Microleaks. You get on a roof in the howling wind, and other calls waiting and just may find that an electronic works better. I had a copper-to-steel joint that had microleaks, barely would make a cocoon.
    But my inficon (the more expensive one, like $310 usually like 325-350) picked it up instantly.
    And you can charge more if you start calling the bubbles "leak reactant"
    It's great to be alive and pumping oxygen!
    Feb 2007
    Central MD, Carroll County
    I still use the tried and true johnson controls hg10 formerly made by GE it picks up a leak as small as 1/2 ounce per year. The down side is that it requires a120vac source to plug it in and the cost its about $400. That and the sensors like to go up often
    Apr 2008
    Maryland
    Thumbs up
    I agree H-10. Still the best in my opinion. You can get them with rechargable battery.
