Results 1 to 8 of 8
    Jun 2006
    n.texas
    What are my options
    customer needs outddoor HP replaced (kid ran into it caved it in with dirt bike just got for xmas) # twpo36c100a3 indoor twe036c140bo. i think 12 seer. Is it possible to add new outdoor and change txv at air handler
    Jul 2002
    Zelienople, Pa
    Check with your local Trane distributor.
    They will know best.
    Springfield, Virginia, United States
    i believe you can add a txv to almost anything
    Possible yes.
    Should you? Call the distributor and ask them.
    Before the new AH line came out, the 13 SEER units had some ratings with older AHs like the TWE-C series WITH a TXV. We've done a few with no charge issues.
    for the cost that you would/should incur for txv install/retrofit you should get a new airhandler and enjoy a reliable and comfortable system, good warranty maximum lifespan...
    if youre gonna do it do it right
    That is a 12 SEER outdoor unit. An XR13 outdoor unit will match up with that air handler if you install a TXV kit.
    You can either use the kit Trane sells that will screw right onto the fitting, or install a sweat fit TXV just before the fitting. Don't forget to remove the orifice.
    Jun 2006
    n.texas
    thanks all
    i changed outdoor unit today along with txv allswell thanks MARK.
