Results 1 to 7 of 7
    Apr 2008
    Carrier SEER and SIZE
    I just purchased a new house with a carrier Heat Pump. I have the following model #'s Outside-25HBA360 Inside - FX4CNF060. Can someone confirm the SEER rating and size of these units together for me? Everything I read says the 25HBA360 indicates a 13 SEER 60000 BTU (5 ton unit). There is a sticker on my AHU that says this unit is 14 SEER (which is what i bought) does the combination of units Equal a 14? Also I know to do this right calculations must be done but house is 2800+ SF with lots of glass east and west living in central florida. Does this unit seem undersized? Thanks for all your help!!
    SW FL
    Hmm
    Quote Originally Posted by Jeffro11475 View Post
    Could be Right Size ... IF
    glass is tinted
    One can not determine required size
    with knowing the specific layout
    AND S.H.G.C.
    Designer Dan
    DC Metro Area (MD)
    The FX4CNF has a high-efficiency X13 motor, so 14 SEER doesn't surprise me. You're missing a few digits from the end of the heat pump model number--ARI confirms this for all but one of the 25HBA360xxx units (which comes in at 13.50 SEER). Not bad performance from a base unit (in terms of capacity and efficiency) with the exception of the 25HBA360A32, which comes in a bit lower in efficiency.
    Really no way to tell if size is right from here... a load calculation tells you that. Is it cooling/dehumidifying well?
    Apr 2008
    Guys Thanks for the help. The complete Model # is 25BHA360A310. I am still a bit confused though. I actually paid about $200 extra to go from a 13 to a 14. Is it acceptable Industry standard to call a 13.5 a 14 or should I raise a stink with my home builder and try to get my money back? Also I would like to replace the El-Chepo thermostat they gave me with a programable. I was looking at them at lowes and most of them say for single stage only. How can I tell if I have a single or Multi stage unit. Thanks again.
    DC Metro Area (MD)
    You did get a 14 SEER system according to ARI (the American Refrigeration Institute). I said one particular revision of the 25HBA360 only got 13.50 SEER with that air handler--according to what you provided me, yours is not that revision. Complete numbers: 12 EER, 14 SEER, and 8.30 HSPF. Not bad at all for a builder model unit.
    Mar 2006
    The South
    jeffro
    Your system is Carrier's Base model low end HP with Puron and based on ARI performance numbers is indeed rated at 14 SEER.
    see below.
    1179274 Discontinued Systems BASE 13 PURON HP CARRIER AIR CONDITIONING 25HBA360A31 FX4CN(B,F)060 60000 12.00 14.00 58500 8.30 36200
    not bad numbers for cooling but poor heating efficiency and probably will be on the noisy side.
    IMO
    The thermostats you can buy at the Big Box Stores are not the same as HVAC contractors have. The BBS one is usually down graded and had some features disabled.
    Also. If you replace your stat yourself, and something goes wrong. Its not covered under warranty.
    As contractors, we make some good money off of customers that burn up parts by incorrectly wiring their own stats.
    It cost more for us to come out, repair/replace the systems burned out parts, and then install another thermostat, then to pay us the first time.
