Results 14 to 26 of 41
Thread: My (continuing) Rheem Mod saga
04-05-2008, 12:31 AM #14
- Mar 2008
- Central Maryland
- 246
Yes on both counts. My installer had to run a cable with more wires up to the thermostat, even though I had a semi-modern ChronoTherm III. He was also unfamiliar with Rheem's latest modulating thermostat, but I got him to find it and install it anyway.
The wiring is somewhat more complex, I can attest, after spending an hour staring at it making sure he wired it as a mod and not a quasi-mod furnace controlled like a single or double stage.
I get the feeling that 90% of HVAC work consists of customers asking "can you do it cheaper?" and **** long-term costs of buying an 80 versus a 90+ mod.
Not me.
Since most HVAC units are purchased by the people who DON'T pay the energy bills (building contractors and rental owners), why would any installer be familiar with the good stuff?
I also get the impression that linear increases in wiring complexity result in logarithmic increases in installation mistakes.
-HF
04-06-2008, 06:30 PM #15
It's got 1 more terminal and it's marked with a V at both ends. If your installer messes that up, he needs to find a new line of work.
04-06-2008, 06:35 PM #16
- Feb 2006
- 96
Doc do I just need to wire in a humidistat to run the On Demand Dehumidification?
04-06-2008, 06:38 PM #17
No, there is more to it than that, it depends on your application. Do you have a two stage cooling unit?
04-06-2008, 06:40 PM #18
- Feb 2006
- 96
no single stage
04-06-2008, 07:15 PM #19
Then the ODD jumper has to be removed and yes. Just remember to use a close on humidity rise. (humidistat)
04-06-2008, 07:24 PM #20
- Feb 2006
- 96
ok thanks
I really enjoyed my first winter with my MOD
no complants especially with my heating bill and electric bill being so low
04-06-2008, 07:35 PM #21
Is there a Y2 on the thermostat? Yes, there is, it's a mod stat. (I would have your contractor connect that to the Y2 (YH) on the furnace and pull the ODD jumper rather than waste my time with a humidistat). You'll make your single stage cooling act like a 2 stage, lowering your sensible capcity and increasing your latent work when 1st stage cooling is called for. If second stage calls, it will bring the fan to full speed and bring the sensible up to handle the temperature you feel.
That's not in the book, but it's good advice (and probably should have been done at installation if they sat through a class that discusses ODD).
04-06-2008, 08:16 PM #22
- Feb 2006
- 96
thanks again doc
04-06-2008, 09:02 PM #23
- Feb 2007
- 997
Hey Doc, that's really good information (not in the installation manual), if I ever get to have one installed. I was more concerned with humidity control (ODD), and never really got into 2 stage a/c's. While we average around 1000 cooling degree days, having longer running cycles would help during milder humid weather.
Would you know what the sensible capacity of an RANL-042-JEZ with coil RCFLHM4821AC would be in 'first stage'?
Full capacity is 30,350 BTUs sensible.
Guess I'd need 7 wires for the stat. You're always good for some useful information.
AM
04-07-2008, 09:17 AM #24
There is no published information, but it will not make it a two stage unit. The sensible capacity could probably be figured out once it's installed but I would imagine it's something like 92%-100% but that's enough to stretch your run times and increase the latent work.
Fact is, the furnace has it, the stat has it, why not do it at the cost of one wire?
04-07-2008, 12:01 PM #25
- Feb 2007
- 997
My mentioned coil has excess latent capacity as it was selected based on its (derated) sensible capacity. Operating as you've described above, the driving force would be temperature, rather than humidity.
Based on your estimate (won't hold you to it), I wonder if using a humidistat would achieve better (humidity) results by forcing low speed blower for as long as it takes to reach a level of say 45 - 50%.
AM
04-07-2008, 09:43 PM #26
The control would be based on actual humidity if you chose to do it that way, assuming your humidistat is located in the right place and it were accurate. I just calls em as I sees em. The unit set up like I mentioned will not make your house too dry by any stretch but you will have no problem achieving a 45% rh home either.
