Results 1 to 8 of 8
Thread: Bryant Question
    Jan 2005
    Seattle
    Bryant Question
    Hey can any one tell me if a Bryant number 312AAV024045ADJA
    is a two stage variable. Or is it just a two stage.
    Thank you in advance.
    41
    Jan 2005
    Seattle
    Bryant variable
    Well when I look at that chart it would seem that it is a variable. But...
    Now it has been a while sence I have installed one of these. But as I recall
    The variable don,t have a black,yellow,red and blue wires to select fan speeds. The variable speed motors are a differant looking beast are they not. I was wanting the "DC" motor for the energy saving and low air flow of the continuous fan. I have a pretty good air filter "system" that I want to take full advantage of.
    41
    Jul 2000
    Northern Wisconsin
    http://www.bryant.com/products/furna...ferred80.shtml
    If you look under the product specs tab you'll see that it lists the blower as two speed, not variable.
    Virginia
    the 315 is vs 2 stage 312 is 2 stage psc motor
    Jan 2005
    Seattle
    bryant315 AAV
    So does any one have a list showing the tonage and BTU outputs(high and low) for the 315 AAV?
    As always thnk you in advance for the help.
    41
    Jan 2005
    Seattle
    Red face bryant315 AAV
    Anyone... I got to get this little problem of mine figured out. Don't they make a 70,000 BTU 3 ton? Does anyone know what it burns (btu wise) in low fire.
    I need to find get the model number for the 80% two stage with the variable speed blower motor. PLEASE!
    41
