    Apr 2008
    Louisiana
    Enthalpy formula
    Hi all. I'm new to this site and am working on an econmizer program today. Program is written in GCL. Does anyone now a formula to determine outdoor air enthalpy based on the inputs from an outdoor air temp sensor and outdoor air humidity sensor. Any help is appreciated.
    Nov 2007
    I have a paper from ASHRAE that you could use to derrive the equation....It is not pretty!!!!!I'll e-mail it too you if you want.
    You may be better off (less time & code debugging) buying a transmitter that outputs enthalpy...Vaisala is a good Mfr.http://www.vaisala.com/instruments/p...y/fixed/hmt330
    Feb 2005
    Where it's dark & damp
    Enthalpy = 8 + 0.27 * (Dry_Bulb - 35.0) + 0.5 * ((Dry_Bulb - 35.0) * (RH/100))
    SW FL
    Quote Originally Posted by GONFISHN View Post
    .. am working on an Economizer program today. Program is written in GCL.
    You can discover accuracy of formula offered by Willf650 through testing.
    I guess you can review ParksSoft Online, purchase or
    discuss by sending email to Bob Parks
    support _at_ parkssoft _dot_ com
    Parks Software
    P.O. Box 162
    Gradyville PA 19039
    Add comparison
    35 EZ Air 8 + 0.27* (DB-35) +0.5 ((DB-35)*RH/100))
    DB DB - 35 WB RH CALC Formula Difference
    1
    95 _ 60 82 _ 58.0 __ 45.64 41.60 __ 4.04
    90 _ 55 80 _ 65.1 __ 43.47 40.75 __ 2.72
    85 _ 50 75 _ 63.3 __ 38.42 37.33 __ 1.10
    80 _ 45 70 _ 61.2 __ 33.93 33.92 __ 0.01
    75 _ 40 65 _ 58.8 __ 29.93 30.56 __ -0.63
    70 _ 35 60 _ 56.1 __ 26.35 27.27 __ -0.92
    65 _ 30 55 _ 52.8 __ 23.13 24.02 __ -0.89
    60 _ 25 50 _ 48.9 __ 20.22 20.86 __ -0.64
    55 _ 20 45 _ 44.3 __ 17.59 17.83 __ -0.24
    50 _ 15 40 _ 38.8 __ 15.19 14.96 __ 0.23
    45 _ 10 35 _ 32.2 __ 12.98 12.31 __ 0.67
    40 _ 5 30 _ 23.4 __ 10.90 9.94 __ 0.97
    35 _ 0 25 _ 11.7 __ 8.93 8.00 __ 0.93
    Designer Dan
    Wisconsin
    ACI Enthalpy transmitter
    ACI also carries Enthalpy Transmitters with considerations for Elevation
    http://www.workaci.com/pdf/Humidity/...an.pdf#zoom=80
    Enjoy your day!
