Results 1 to 13 of 33
    Apr 2008
    North Myrtle Beach
    Talking Heat Pump advice
    Hello all,
    I am purchasing a rancher in N Myrtle Beach. One heat pump is shot so I plan on replacing both of them. The units there now are two 2- 1/2 ton goodmans.The house is 17yrs old and I am confused on which brand and what SEER to buy. I have gotten estimates for 15SEER variable speed and 13SEER not variable speed air handler. So I am asking should I just go with the 13SEER and save . Thanks
    Mar 2006
    The South
    motown
    just to clarify, these prices are for one system or two?
    td
    Wisconsin
    You better remove the prices. The people that run this site have this thing against pricing for whatever reason. I don't see what the problem is, but they don't like it.
    Remove the prices or the mods will.
    Whats the problem with posting prices.
    One contractor might come on and say that any company installing 2-2.5ton 19i's for that price are lowballing scum bag hacks. Not possible to get them installed properly for that hack price.
    Then the next contractor might come on and say thats too much, any company charging that much is ripping you off.
    Now how will the poster asking the question know who to believe.
    In one situation, one is correct, in another situation, the other is correct.
    To the OP.
    Your not comparing apples to apples.
    The Tranes are 2 stage, the Goodman single stage.
    Is the Goodman contractor having the coils coated to protect them from the salt air if your near the actual beach.
    The Trane aluminum coils should hold up ok without coating.
    Get prices of other 13 SEER units.
    If you want them to last, you'll get them coated.
    Get prices on comparable equipment, and them come back and ask questions about the units.
    Jun 2007
    The Twilight Zone
    Your true cooling costs are determined by the Energy Efficiency Ratio (EER) and not SEER. Whichever SEER systems you get, make sure the EER is 12 minimum. This will provide you lower operating costs in the heat of the summer when you need it the most.
    In my opinion, a heat pump with 14 SEER / 12 EER / 9 HSPF provides the best combination of purchase price and true operating costs.
    FYI: 19 SEER units have two compressors, 16 SEER units have one dual-speed compressor, and 13 thru 15 SEER units have one single speed compressor (as do most residential systems in use today).
    A good install is critical, regardless of brand chosen.
    Good luck.
    Apr 2008
    North Myrtle Beach
    Prices are removed...sorry
    HSPF is to heating, what SEER is to cooling.
    On a heat pump, look for high HSPF and COP ratings. Not just HSPF,
    Then why do I still see them?
    Apr 2008
    North Myrtle Beach
    is that ok now?
    Quote Originally Posted by motown92 View Post
    is that ok now?
    No, it's still there.
    You still got the VS lowest price, and the Goodman price.
    Apr 2008
    North Myrtle Beach
    I took all references to prices out.
