Thread: Definition of Efficiency?
04-02-2008, 09:55 PM #1
- Mar 2008
- 8
I am still having a difficult time in deciding on a system for my new home. I was curious what the pros thought the definition of an efficient system. I've gathered that a SEER rating is more of a marketing ploy than an actual measurement of a good system. If an efficient system a properly sized unit with a high SEER (15-16)? Am I better off going with a low SEER (13), properly sized system with a variable speed blower and dual stage compressor for better efficieny and comfort? This may be all dependent on the particular system, but knowing nothing about HVAC, I just feel like I'm not getting the whole story.
04-02-2008, 10:02 PM #2
What are you................
04-02-2008, 10:07 PM #3
efficiency?
get a heat load calc and get a carrier hybrid. maxx it out and get the bells and whistles
Infinity and learn how to use it and maxx out warranties
huge rebates right nowLast edited by acmanhoney; 04-02-2008 at 10:13 PM.
04-03-2008, 05:12 AM #4
Professional Member*
- Nov 2004
- SW FL
- 5,252
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
04-03-2008, 06:42 AM #5
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
SEER is a good comparision number.True you install will not be at those test conditions,but still a good method to compare models/brands.
The design of your new system,load calc,equipment selection,and duct design will determine the effeciency of the installed system.
04-03-2008, 07:13 AM #6
Since your GC ing your new home.
Make the envelope as efficienct as you can. Then have an acturate load calc done.(can be done from the prints, with the updated values)
After that, picking the right size and efficient equipment is easier.(somewhat)
