Results 1 to 7 of 7
    Apr 2008
    air vs water heat pumps in massachusetts
    Hi all,
    I am trying to decide on air source vs water source heat pump for residential hvac north of Boston MA.
    Ground loop is not a possibility pump & dump not a possibility. SCW with bleed is a possibility.
    GWHP sounds great but I cant get a handle on the well pump losses.
    I have heard that the well pump bill can approach the heat pump kwh usage.
    So much for high COP numbers. any comments on that?
    Also how long will a well pump last under heat pump type loads?
    Heat load calc is coming, currently whole house is adequately heated with .85 gpm oil burner. around 100kbtu/h.
    Install even though i have the well already is $$$$ for geo, less for air.
    not sure i can recoup the difference. any comments?
    thanks!
    Taunton, MA
    sounds like you have an oil fired warm air system, i recomment a good efficient 3 pass boiler with a hydro-air unit and indirect water heater, it's a good set up in your area
    Apr 2008
    thanks hotwater
    pretty much have that except the burner is about 9yrs old.
    went through 1400 gallons of oil last year not looking to do that again.
    insulation quote on the way.....
    1400 gallons??......where did that much oil go? Are the windows closed when you have the heat on? J/K...but really, that is ALOT of oil burnt for a home heating, unless you've got a 5000 sq. ft house!!!
    You're right on the insulation thought, no matter how efficient the heating unit could be, if the heat is just going outside, savings will be challenging. Improved insulation gives comfort too, improving the burner efficiency won't do that.
    SW FL
    Question
    Quote Originally Posted by Dunfudgin View Post
    pretty much have that except the burner is about 9 yrs old.
    ... sounds like dual fuel should be evaluated
    .. TWO air source heat pumps might be reasonable
    Designer Dan
    Apr 2004
    Quote Originally Posted by casturbo View Post
    Really, that is average I feel.
    Apr 2008
    good guess on the footage
    4500sf +hot water is off the oil as well.
    I know we have infiltration problems, cold floors when it blows etc.
    air handler in the attic. have to condition that space.
