Results 1 to 13 of 25
    Lucas, TX
    Heater kit installed backwards
    I have a 2002 era Goodman ar36-1 with a heater kit.
    Looks like someone put it in backwards. The arrow that identifies the
    air flow is pointing in the wrong direction.
    Is this bad, dangerous, worrisome, or other ?
    Thanks.
    Quote Originally Posted by adamk View Post
    Thanks.
    If it's electric heat,I think the over temperature devices might be in the wrong place ,so if the fan failed it might get hotter then designed before the trip out.Could be a fire hazard,again IF it's inverted.
    Worth having it checked .
    Have it reinstalled the right way.
    As dash said, the safety not sensing temp tight is the concern.
    Lucas, TX
    Okay, I was wondering if there was a order the heating elements came on
    and the sensing for the next element. Less heat would bring on more elements
    than were necessary.
    Adam
    Depending on sensor positioning, it wouldn'r make a difference.
    Jun 2007
    Round Rock
    We don't install Goodman's. But you would think that they would only make it so it goes in 1 way. It wouldn't be that hard. Just make the screw holes line up 1 way. I guess some yahoo would just drive screws in where they wanted them with their nut driver on their cordless.
    Jun 2007
    Central, FL
    STOP!!!
    Yes ,the arrow needs to be pointed in the airflow direction, call a pro to check it out DO NOT ATTEMPT repairing it yourself very dangreous!!!!
    WARNING:IF YOU DON'T KNOW THEN DON'T DO, SO THOSE WHO KNOW WHAT YOU DIDN'T KNOW DON'T END UP UNDOING WHAT YOU DID SO IT COULD GET DONE RIGHT!
    N.E. Ok.
    I believe the kit is marked with airflow direction stamped on it for upflow or downflow depending on the application, same airhandler.
    southern mo.
    some of the kits go one way in a package unit and the other way in an air handler, might be ok, have it checked out
    Jun 2007
    The Twilight Zone
    I have the HKR-15C heat kit on my Goodman ARUF air handler. If yours is like mine, you can easily remove the 6 sheet metal screws that hold it in place, flip it around and re-install it properly (kill power first to be safe). Mine is electrically connected to the air handler with a male/female connector.
    Good luck.
    Feb 2005
    cincinnati ohio
    220 v
    Yea & he could aslo burn his house down too ! No diy info
    My avatar is a picture of a Goodman Silencer .....These were commonly used in Goodman country ....Photos by hvac tech ( PaysonHVAC )
    Lucas, TX
    > 220v ...
    Yes, 220v, 60a.
    Lot of power can flow in there. Hence the worry about the orientation.
    Adam
    SC
    You need to fix that. Most likely never cause you a problem, but it could also one day burn down your house. Don't play with fire, get it fixed.
