Results 14 to 26 of 64
Thread: humidity
    dalton ga
    Humidity
    Leftover Humidity Can Only Cause Prob. ----get Rid Of It... Mildew-- Mold. Algae---get Rid Of It!!!!!
    dalton ga
    Humidity
    Kixtusjon Who Are You . I Am Donnie Bates Dalton Ga.
    dalton ga
    Yes- Fan On Causes Water And Hum. To Be Added To Your House. But If It Does ,your A/c Sys. Has Been Sized Wrong!!!!
    South Florida
    Question
    Quote Originally Posted by NGHTYRTE View Post
    What are you talking about? How is putting moisture back into the air by running your fan constently getting rid of humidity? By running to fan constently, you put humidity back in the air.
    Too Few Pro Tech's & Too Many Parts Changer's.
    SA
    You Did Not Give Your Sq. Footage Verses A/c Tonage. It Can Be Fixed
    Are you trying to get pro member ship with all these post in one thread
    Sq. Footage has little to do with tonage in humid climates.
    you can not tell if his AC is oversized by info he has stated. there could be a number of issues.
    South Florida
    ??? When an a/c condenser shuts down and the fan is in auto, is there moisture on the coil or in drain pan??? If so, when the fan is on and condeser off, the moisture will start to evaperate back in to the air because of the air coming back to unit will be higher in temp than the air that left the moisture when it left the coil. And what does my name have to do with anything here? If you don't agree with me thats fine. It does not effect me in anyway.
    Madison, WI/Cape Coral, FL
    With the low cooling loads in FL, 50%RH sounds good to me. Like a lot of the rest of the posters-- what are measuring the %RH with? Do not totally trust any meter. At 75^F, 50% RH, Any cold surface below 54^F will fog. A good thermometer may be easier to come by than a accurate %RH meter. Another way to check %RH is to measure the temperature of water that fogs a shiney bowl. First calibrate your thermometer with crushed ice (32^F). Slowly cool a bowl of warm water with ice until the bowl fogs. The temp of water at foging is the dew point. Plenty of info on web to figure the %RH from the air temp and the water foging temp.
    If you are getting enough fresh air in your home and the a/c is not running much, the dew point in your home is higher than outside. Here comes my line so I don't disappoint. Homes in green grass climates with adequate fresh air need supplemental dehumidification to maintain 50%RH during shoulder a/c season. OK Regards TB
    Jun 2007
    Central, FL
    Over sizing in florida is very unlikely, most contractors squeze every btu possible out of a a/c system out here. In florida new home construction is very cheap most GC call it "Lego" construction. Most new homes use the new fibercrete (fiberglass added to the concrete) for the foundation, and do not add any nylon film under the slab. This causes moisture from the soil (florida swap land ) to go up into the slab and in the home. We have seen this problem quite a bit here in centarl florida, we use for new construction the variable speed Bryant ahu w/thermidistat control. Wire the Dehum on the board to the stat and remove the J1 jumper on board, works like a dream. In florida 40%-45% is real nice humidity, I like it at 44% so I can set my stat at 77F.
    WARNING:IF YOU DON'T KNOW THEN DON'T DO, SO THOSE WHO KNOW WHAT YOU DIDN'T KNOW DON'T END UP UNDOING WHAT YOU DID SO IT COULD GET DONE RIGHT!
    dalton ga
    Humidity
    Acdocatrang.--sounds Like You Have It In Control ---good Job
    SA
    Talking
    rig it so your ac runs non stop and when in door temp gets below your set temp your heat strips come on so it doesn't get to cold.
    but seriously the best thing would be to get a good tech out there. There is no way for us to diagnose you problem without going to your house. There is a lot of things that can cause high humidity even things other than your AC
    South Florida
    Quote Originally Posted by AcDOCnTRAINIG View Post
    I am further south of you, and sell the Nordyne 410a VS 14 seer or higher. I very rarely sell 13 seer units anymore. You are right about the dehumidistat to the control board. That 45% humidity is sweet!!! They think you are a hero.
    dalton ga
    Ifyou Are Putting Moisture Back In The Air,,theres A Prob... Sorry If You Dont Agree....
    dalton ga
    Humidity
    Kirtusjon-- Do I Leave Or Believe
