Results 14 to 15 of 15
    Virginia
    Quote Originally Posted by Swampfox View Post
    We dont charge for leak searches, other than for the time involved, sell too many new systems by using the leak detector and finding evap coil leaks, Im glad to pull it off the truck and take a look
    i agree ,if we find a unit low charge on a spring check we perform a quick leak check as part of it most of the time you can find the leak if a leak is not found in about 30 mins then we tell the ho there will be a additional labor charge .
    Ohio
    Quote Originally Posted by catmanacman View Post
    So before you leave why not throw in some dye? Charge for the dye and the re-charge on the unit and then when you come back you should have your leak found in no time.
    I need a new signature.....
