Results 1 to 2 of 2
    Oxygen Barrier in Pex ASTM O2239
    Just removed about 1000 feet of 3/4 inch pex. Lots of dark material. Is this because the pex above (might be D2239) does not have oxygen barrier?
    I assume it it necessary that all radiant floor installations SHOULD use oxygen barrier pex.
    Anyone know if ASTM has a website to check if this has or does not have oxygen barrier.
    Jul 2001
    Your best bet is to go to the manufacturer. ASTM does have a site. If you Google ASTM D-2239, you will go to their bookstore. They will tell you what the standard is for plastics. They define the standard. It is up to the individual manufactureres to produce a product that meets the standard and only they can tell you if they do.
