Results 1 to 13 of 17
    philadelphia
    19 Fa teardown (three piece bull gear)
    just got done a Fa #5 set screws broke in bull gear and fell into oil pump. drilled out set screws and tapped to 3/8" with one solid set screw then TIG welded the screws in and ground flush. have pictures but don't know where or how to post them. The bull gear is made of three pieces the hub and the two helical gears it is pressed on and drilled on the center line and set screws are put in . only know of one other chiller that has this type of gear i don't think there are to many out there.
    Wichita Ks
    I only worked on one, had to remove the motor to install new sensors. There is only 2 in this area. They are both at a nuclear plant and still using r12.
    philadelphia
    this one is r-134a and the other one is 12 there was another company taking care of this machine and there was a problem with the starter it would start and stop consecutively during start up and i think that starting stopping starting torque sheared the set screws. pretty interesting they let it do it for as long as they did
    Aug 2000
    Under my tree
    LOL, but they "saved" money on fixing the starter.
    Quote Originally Posted by DITAW View Post
    To much work with too little time!!!!
    philadelphia
    tried to attached the pictures but they are too big know of a site i can post them on.
    Jun 2001
    Greeneville, Tennessee
    Picasa
    Try Picasa
    http://picasa.google.com/
    I have used this program for several years now.
    You can upload picture online and let customers see their equipment, with out the hassle of them opening email attachments and down loading.
    This is a free service. You will have to download on your computer for initial setup.
    I have not had any software conflicts and I have installed on several computers.
    Dealing with Global Warming
    philadelphia
    i tried using it every time i go to upload the pictures it just keeps retrying says connection failed . thanks though
    philadelphia
    i had to shrink the pictures down took a little time
    philadelphia
    Oregon
    That rigging job looks a sh!!ty as the overhaul I am on.
    Aug 2000
    Under my tree
    Nice pics.
    Rochester,N.Y.
    I was wondering who you worked for.I work for Carrier in Rochester,N.Y..I haven't torn down a fa closest beast would be a 17EX.I haven't seen any updated litature on the fa problems like the one your talking about.Was this a problem from the factory or application problem???
    windy city
    can i ask what you have on the motor barrel lift lugs. always trying to use new ideas.
