+ Reply to Thread
Results 1 to 11 of 11
Thread: Voltage drop at tstat
    Nov 2014
    Nj
    I have 24 volts at my common on control and I only have 10 volts at thermostat . What would cause this voltage drop ?
    May 2014
    Bay Area California
    Loose connection, not measuring the voltage proper, an excessively long run of stat wire for the gauge, a load drawing too many amps or a combination of any of the above.
    Southeastern Pa
    Quote Originally Posted by Rox9142 View Post
    Are you an HVAC tech or the homeowner?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Nov 2014
    western NY
    Are you saying you have 24v across r-c at unit and 10v across r-c on tstat with common hooked up to stat?
    Nov 2014
    Nj
    I'm a tech
    Southold, NY
    I'm a tech
    Oct 2011
    Chicagoland Area
    Why does the common have voltage?
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Southeastern Pa
    I'm a tech
    I try to avoid giving a lot of technical advice in the open forum areas.
    Use the link below to learn about our FREE pro membership that allows you to post in the Pro forums, where we routinely address these questions.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2014
    Columbus, Ohio
    Post only one thread, not dozens of them.
    What terminals were you on at the stat when you got the 10 volt reading.
    Dec 2013
    Ontario, canada
    What's ur transformer s va rating and what is your total va required do they match up ?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
