Results 1 to 13 of 14
Thread: Help decode this model number
03-23-2009, 06:41 PM #1
Professional Member*
- Aug 2007
- Okmulgee, OK
- 184
A good friend just bought a repo house and the previous owners took the condensing unit.
It's a triple wide trailer house that has a Nordyne electric air handler.
air handler numbers
model-- B3BV-000K-B-15B
serial-- B3D050512982
there's another number on the nameplate
903517B
Where's the cooling btu's?
03-23-2009, 07:27 PM #2
B3BV is vertical only model, the 000 should be the airflow not 000. Say 036, 042 etc. K is 208/230/1, B is width of 19.25" and 15 is kw. Did not see anywhere that 000 is possible.
03-23-2009, 07:38 PM #3
- Aug 2007
- Okmulgee, OK
- 184
Thanks for the reply. It had the model number on it in 2 seperate places and they both read the same- 000. I don't get it....
03-23-2009, 08:08 PM #4
- Mar 2005
- Houston, Texas
- 11,646
03-23-2009, 09:12 PM #5
Better call a Nordyne supplier. I looked through the spec sheet again and didn't find a 000.
The B width cabinets were used in 2.5 through 4 ton air handlers. If there's a piston size sticker on it, that would tell.
03-23-2009, 09:19 PM #6
- Aug 2007
- Okmulgee, OK
- 184
03-23-2009, 09:25 PM #7
- Mar 2005
- Houston, Texas
- 11,646
03-23-2009, 09:42 PM #8
No return.
- Jul 2006
- NW burbs of Detroit
- 6,058
Get a magnifying glass. I carry one in my pocket on every call. I can't can't remember how
many times i eyeballed a model number and got it wrong when i called in for a part. I would always miss one digit 'til I doubled checked with my magnifying glass.
03-23-2009, 09:52 PM #9
- Mar 2005
- Houston, Texas
- 11,646
03-24-2009, 06:59 PM #10
- Aug 2007
- Okmulgee, OK
- 184
I've messed up on model numbers before. Especially on something like this Nordyne that I don't work on much. BUT, I finally found out that the 000 in the model means that it was assembled with no indoor coil. Found a number on the coil finally.
C3QA-055U-B
917229A
which looks to be a high eff. 4 ton evap coil.
03-24-2009, 08:00 PM #11
- May 2007
- Southern Middle TN.
- 60
03-24-2009, 08:12 PM #12
- Mar 2005
- Houston, Texas
- 11,646
10-12-2011, 03:20 PM #13
New Guest
- Oct 2011
- 1
HEY YOU GUYS! Stop being so mean to my best friend, he doesn't need glasses yet. Okk?
