Results 1 to 11 of 11
    Atlanta(metro)
    Cool Bad Architect - what should I do?
    I've caught a couple of different errors on the blueprints that the architect had to replace. I've talked to him a couple of times and I'm not confident in his knowledge. Should I go back over everything (calculations etc) for him or not? He's now talking about a gas package roof top unit with heat strips - hmmm
    Nov 2007
    From a construction law standpoint, the architect/engineer is the design professional. They carrier professional liability insurance in case they F-up so the Building Owner doesn't get left w/ the costs of their design errors.
    The contractor is obligated to follow the contract documents (drawings & specs). IMO, unless the Building Owner is a very good customer of yours, why stick your neck out anymore than you have too....not too mention wasting time!
    BTW...a bad architect/engineer = changeorders for you!
    Nov 2007
    Atlanta(metro)
    Quote Originally Posted by flyrfan View Post
    Dont know about here in Ga but I did a job in NC where I was told I was responsible as the licensed contractor to make sure everything was to code.
    Quote Originally Posted by reliablehvac View Post
    I would think code means installed correctly. In my book installed correctly and operating to design conditions are 2 different ends of the spectrum. If you feel there are design issues that may fall back on you and not the one who designed the system I'd walk away from it. I do not know any gas fired RTU's that have space in them to add ele. heat. Good luck.
    SW FL
    1. Redesign
    2. or Take responsibility
    3. or Move on
    Designer Dan
    Typically in the specifications Somewhere it will say that you are responsible in some fashion that yo dont really follow. Contractor must insure that installation meets all local building codes or some other bs line. So why the F*** did they hire an engineer anyway? What you need to do is to look over the job, if any questions, submit RFI, and get clarification in writing, otherwise its useless later. If you have objections, you have to get them out there or otherwise you'll be stuck in the middle like it or not. The days of putting it in exactly like the prints show and leaving are pretty much over, in many cases now you wont get paid unless the system is proven to work.
    SW Florida
    1.change order$
    2.change order$
    3.change order$
    Build to plans, follow local codes
    Either email your questions to the architech.
    Or write it out in your qualifications.
    Create a "Paper Trail" when you email, CC a copy to another computer you have good access to. IE from your work computer, to the PE, CC to your home computer. Registered letters, but they can say someting else was in the envelope. Written, signed and PE stamped change orders are a must. Also digital images have been thrown out in court, disposable cameras and poloroids are best. Guard your prints with your life or get a working copy made at Kinkos
    I only have to make it work till I retire.
    Ohio
    It's called Errors and Omissions Insurance. If it's a stamped drawing, the Engineers responsible. But I would still document EVERY correspondence to the Engineer that describes every issue in detail.
    Coincidentally, we just had the same situation. The building owner pissed off the architect, who would not return the general contractor's calls about the MANY screw ups on the stamped drawings. I stopped our job mobilization. I contacted our Engineer who would not revise another Engineer's drawing. He said his insurance would immediately drop him. The only way he'd touch it is if he would re-do the whole drawing.
    Now the owner is trying to make nice to the architect. What a circus.
    Bottom line for me is we will not knowingly start a job that has HVAC code violations.
    jogas
