+ Reply to Thread
Results 1 to 12 of 12
Thread: Pulling vacuum lost power
    Dec 2009
    Confused Pulling vacuum lost power
    well i waited until we had a beautiful day, was blowing 60 mph a lot this last week and we have a lot of outages on high wind days here in Alaska ,so I assumed ( I know ass out of u and me) that power would be good today, low and behold we had an outage anyways I was close and got my valves closed in 30 secs but I was at 30000 microns vacuum , vacuum pump was below compressor and service valves 36 -48 inches lower ,gauges were elevated , oil level just barely below sight glass full level on vacuum pump , hermetic compressor no sight glass Poe oil in compressor, black gold vacuum pump oil ( mineral oil).... So I feel like I should change the oil on compressor, any thoughts
    Dec 2009
    I know that oil level in avacuum pump is checked when running because if you shut it off(after closing gauge valves) oil would be pulled toward system causing false reading
    Apr 2004
    Minnesnowta
    So your concern is, when power went out the vacuum in the system sucked some oil out of your vac pump and contaminated the system? I would say that is unlikely. I say carry on.
    Wisdom has been chasing you, but you have always been faster.
    In your darkest hour, when the demons come, call on me brother and we shall fight them together.
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
    Jan 2005
    Emerald Coast
    Quote Originally Posted by doc havoc View Post
    I say carry on.
    X2
    Do not attempt vast projects with
    half vast experience and ideas.
    Oct 2014
    Columbus, Ohio
    30000 isn't that far away from atmospheric, is it? If any oil did get pulled in, I'd guess that it didn't make it any farther than to your hoses.
    Yup. And stop using your gages.
    "Right" is not the same as "Wise".
    Just because you can measure it, doesn't mean it is important. Just because you can't measure it, doesn't mean it isn't important.
    Nov 2007
    Mississippi
    At 30k microns, your just getting started. Don't worry about the oil. It'll be fine.
    May 2011
    south florida
    If power loss is a common problem you worry about, why not install a normally closed solenoid valve that will isolate the pump when ever the pump loses power?
    Aug 2010
    There's a kit made for this purpose to prevent this. I think it's CPS who sells it. I believe it is like the float ball in a shop vac that chokes the passage when the water rises too far so the motor doesn't ingest the water.
    Dec 2009
    Bought a j&b platinum, no more worries on that end
    Apr 2008
    Tucson, AZ
    Why don't vacuum pumps have a check valve?
    Jul 2001
    Fairfield and NewHaven Counties in Commecticut
    You can use a sporlan solonoid valve
    Quality and Value Service and Repair
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
