Thread: sizing ducting
    sizing ducting
    I am installing a fg6tc120cvcb with a 2stage 5 ton heat pump in a 3 story 4300 sq. ft. house.I have 34 suppy air register.The fan pump out 1870 CFM.Should I down size the run the supply lines to 5 in.1870/34 =55.Questioning my Hvac contractor.
    southern IN
    Do you have any idea what you are doing? From your post I can't for the life of me figure out what you are asking
    The first man gets the pearl, All the second gets is the shell
    Western NC
    NO DIY here. Call a contractor to supply your needs.
    If you are a contractor, do a proper heat load calc using manual J and then duct design per manual D.
    We can't answer a question like that here.
