Results 1 to 11 of 11
    va bch va
    i
    Jun 2007
    Round Rock
    You REALLY need to be more specific. You aren't making any sense and you really sound like you have no idea what you're doing. Almost like DIY'er bait.
    Massachusetts
    Quote Originally Posted by jlt31 View Post
    This maybe an easy qeustion for most but im going to ask.When you read on a peice of equipment. 200psi low and 400psi high how do you break that down on your gauge when adding charge. dont have to be those 2 numbers no peice of equip in mind.Reminder no formal training all on the job.Thank you for your help.
    Don't even try to charge the system. All kidding aside, you run a serious risk of injuring yourself or someone else with your lack of knowledge. If you're serious about being a service tech, then go get the education. Otherwise you're just another wannabe, otherwise known as a do-it-yourself handyman. We can't help you here. Sorry.
    Nov 2005
    Haymarket VA
    Quote Originally Posted by skippedover View Post
    one more vote
    burlington county n.j.
    they are maximum test pressures and have nothing to do with operating pressures.
    step away from the unit and call a pro..........
    Connecticut
    I'll bite - if you are seeing 200 psi on the low side - your compressor is damaged. Probably grossly overcharged which is causing refrigerant to blast its way back into the suction line. Valves are now toast. Need a new compressor. On second thoght, the system could be full of air and/or other contaminants too.
    You need to learn about Superheat and Subcooling. Pressures mean very little. They just tell you the saturation temperature of the gas for the component you are measuring. You cant do a thing with [just the pressures] unless you know what the required Superheat and Subcooling goals are for a unit.
    Oh, and I wouldn't stick around near that system too long. Its going to blow soon.
    Western NC
    Hmm
    No formal training is right.
    Can anyone say poor compression ratio???
    200psi??? Are you looking at an Air Conditioner or an air compressor? PSIG, PSIA, PSI......they are all different.
    Apr 2004
    Charlotte, NC
    Quote Originally Posted by Buck_Taylor View Post
    He is reading the pressures from the data plate, the ones that say TEST PRESSURE. Not that he is reading it from his gauges. Good thought though.
    As others have said. Your reading the coil safety test pressures.
    Now, are you someone just starting learning the trade.
    or a home owner trying to figure out if his system is charged right.
    va bch va
    sorry people
    My cousin is 18 just learning the trade got on site last night on my screen name. Left last night after signing up, did not log out. sorry wont happen again.
    Never say never.
