Results 1 to 13 of 26
    converting to 410, should I replace coil??
    We're changing out our old freon unit to a 15.8 SEER Amana 2 stage 410 unit and are not sure if the coil needs to be changed. Our contractor mentioned that theres kind of an industry argument about whether cleaning the oil out of the old coil is acceptable or not, and I just wanted to get some opinions. The existing coil is from 2004, and its a Carrier CE3AXA060000ABAA. It says it can use 410 with listed units. I don't know the SEER rating on it, and our guy is checking on it, but if it can be used, what are we losing by not changing to a new one? Its a huge expense for the new one, so it would really have to save a lot of electricity to make it worth it.
    Any input would be greatly appreciated!
    Longview,TX.
    You won't get the rated efficiency with the old coil and a lot of mfgs. won't give the 10 yr. warranty with a mis-matched system. Don't know about Amana.
    MN
    replace the indoor coil also, the ratings on a 2004 coil to a 2008 condenser may not have an ARI match, and you will not qualify for any rebates, and worst case the mixed oils in the system take out you compressor, and it is not warrantied due to a mismatched system.
    You can't fix stupid
    Houston,Tx.
    Quote Originally Posted by laff66 View Post
    This may be true but you will have to change out the TEV a R-22 TEV is different than a 410A valve, maybe you can save the coil, hope it all works out for you.
    Mr. Bill
    Jun 2007
    Round Rock
    It will probably work fine as long as the metering device is changed and correct. Which for that will require a TXV. You will probably be changing the coil in 2-3 years. It will probably start leaking. You might get a better deal by doing everything at once, than by coming back in 3 years and changing just the coil. I'm not sure about Amana, but I think they like a matched system and your warranty depends on it. I don't deal with them but once or twice a year, I would definitely check that. A compressor costs about twice that of a coil. My experience tells me that this is a case of pay now or pay more later.
    A mismatched coil on that 2 stage Amana, could get you operating trouble, that the installer won't be able to fix. What size is the Amana.
    Plus, You better check, it may not get 14 SEER if its not a VS blower.
    Is your blower a VS blower.
    If its not, you could end up with high humidity in the house.
    Before I mismatched a 2 stage to another manufacturers evap coil, I'd get a single stage, and a matching coil.
    burlington county n.j.
    match the coil to the unit or buy a low end cheap unit if you want to save money.
    The oil is one issue, but coil volume is another. The newer systems operate differently than the older(yes even five years ago) systems and require different matchups. If you dont match them up,. why spring for the higher efficiency unit, it wont work to its ability anyway. There have been many analagies for this, my fav was putting your old transmission in your new car. Yes it will work, but not like the manufacturer intended.
    We do not have a VS blower. In response to the question about the Amana unit size, were you looking for tonnage? If so, its a 5 ton. As always, that you for the very quick responses, and it sounds like a new coil is the way to go. We'll be in this house for a long time, so if its going to happen anyway, I'm thinking we might as well bite the bullet now...
    Massachusetts
    Well, if you are in the habit of purchasing a new car but keeping the interior from the old car, then definitely keep the interior of the old system. Otherwise, spend anothe nickel and get the whole system done new. You expect it to run from 5 to 7 times longer than the auto your'e driving, so why cheap on the installation to save a few bucks? And that's just the capital expense. When you factor in the added operating costs of a lower efficiency over 15-20 years and escalating electricity prices, a new coil is a bargain. Think carefully before you pass on the coil.
    That Carrier coil can likely be used with Puron/R410a,but not with another brand,just asking for problems,go with a matching Amana coil.
    leland nc
    you are install a top line unit and cutting corners on it at the same time. This makes no sense
    replace the coil and have a matched system for years of trouble free comfort
    Okay. I'll do it. I didn't actually choose such a top of the line unit, its just that its kind of a brother in law deal, and he got a few of them on closeout at the end of last season, and is selling it to me for the cost of a less expensive unit. I was just going on what he said as far as the extra expense, and that it was pretty huge.
