Results 14 to 18 of 18
    Sep 2006
    Quote Originally Posted by airmanmod View Post
    daikin is by far the very best in vrv tachnology, they do have a single phase line if equipment. Also they are alot easier to set up
    Yes, the VRV-S model is the single phase line within the commercial VRV line up and suitable for residential applications.
    Oct 2007
    kansas city mo
    i do agree with you todays technology takes alot to keep up to and vrv tech is not for your every day service tech
    Nov 2007
    (2) other products to consider:
    Samsung's FJM Free Joint Multi System , offering 2 ton and 3 ton capacities; able to offer 2, 3 and 4 zones depending on the condenser selected. You can mix / match the air handlers between a choice of ducted/fan coil style or standard wall mount. (Remote or wired controller)
    Samsung's DVM line - Variable Refrigerant Flow technology, up to 500,000 btus. Single phase and 3-phase condensers, array of air handler options: Ducted (standard, medium and high static), 1 way and 4 way ceiling cassette, wall mount, and more.
    Oct 2007
    Hi Buck-
    I'm in CT and interested in mini-split a/ c system install. How can you be contacted?
    You can email me at email address in public profile.
    Quote Originally Posted by rally1 View Post
    Hi Buck-
    You can email me at xxxxxxxxxxxx
    Please edit out your email address, they are not allowed in post. You can put it in your profile. Thank you.
