Results 14 to 26 of 31
    Rochester, MN
    yeah... I sure hope they got make up air!
    Kinda over kill with a finished ceiling in that room.
    Hell Hole Swamp
    The only way that would have a prayer of working would be to rig a squirrel cage fan in there
    Northern Colorado
    Come on guys! These are really heatpumps for the building next door. I can hardly believe that anyone would actually do this. Hacks!!!
    Hvac Maniac
    "A negative attitude cancels out positive skills."
    Arizona
    Wow. I haven't seen anything that crazy sine I worked for DNC in Phoenix.
    They installed two American Standard Over/Under RTU's in a attic type space in a church.
    Installed HARD DUCT ontop of both units and over to a exhaust fan through the concrete.
    The bad thing was you could never access the condenser fans because it was HARD DUCT all the way!
    True Heavy Metal Geek
    Mar 2002
    fort walton beach fl.
    Just think, The guy whom did this is wondering why its in the wall of shame.
    I worked on a bank that had 4 condensors in an enclosed area like this, I installed an upblast exhaust fan on a contactor than installed a dpdt reley in all 4 units that energized the contactor on make and wired them so only one kicked on it brought the fan on, there was alo open ventilation in the room from decorative block in the summer out here it was 132 deg in the room..I cant believe those units wont trip on high head
    Feb 2005
    L.I. NY
    The installler was just a little confused, the evaporators are located outside
    SW Ohio
    It looks like the basement walls are blocking the air flow on two sides for the one on the left and at least one side on the other.
    Did you aks why they did this.
    Madison, Wisconsin
    There has to be a good story behind this one...
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    PDX
    Quick question: (I know it's a hack and all...) Does it cool the house?
    Gone
    That company’s slogan had to have been:
    “Double your pleasure and double your savings”
    Feb 2007
    Judging from the hard start kits, manual reset high pressure switches and over sized condenser coils (especialy the unit on the right), they must be 13 SEER or higher. How recently were they installed?
