Results 1 to 13 of 15
Thread: Digi-cool 1200 gages
03-22-2008, 09:38 PM #1
- Mar 2008
- liverpool ny
- 25
what manifold do you guys recommend using with the drsa 1200 or 1250 when it comes out? I'll go ahead and say money not being an issue because I like going for the best.
03-23-2008, 07:56 PM #2
- Sep 2002
- 717
The 1200 was made to connect directly to a Yellow Jacket Titan four valve manifold. It will connect to any other manifold using the 90 degree swivel fittings. However it looks much neater when on the Titan. Some like this manifold and some do not. It is what ever you prefer. The 1250 is the same digital except it has 2 temp probes and backlighting.
03-23-2008, 09:41 PM #3
- Mar 2008
- liverpool ny
- 25
since they make that manifold for just about every type of refrigerant and i plan to get into commercial hvac, does it matter which one i pick? sorry if im being a pain, i just dont want to regret getting the wrong one.
im not sure if the differences in the manifolds are just the gage on the manifold or if there are seals or gaskets in the manifold specifically made for the designated refrigerant.
03-23-2008, 10:11 PM #4
- Sep 2002
- 717
What kind of work do you do and what kind of manifold do you have now?
03-23-2008, 10:40 PM #5
- Mar 2008
- liverpool ny
- 25
im in school right now and im using Just Better gages. i intend on getting into commercial work rather than residential but i also want to get the gages while im in school so i can learn on them instead of figuring them out on the job. i think my class equipment really only uses 134a, 401a and 410a.
03-23-2008, 10:48 PM #6
- Sep 2002
- 717
I am sure there will be some that disagree but I have had good luck with the Titan manifold. If that is the way you go make sure it and the hoses are rated for 410a and you will be covered.
03-24-2008, 01:59 PM #7
- Mar 2008
- liverpool ny
- 25
Makes sense, thanks alot! I appreciate the help.
03-24-2008, 03:19 PM #8
I have not been following this thread very well................so, you buy the Digi-Cool set up and install it on your existing manifold whatever brand it is? Correct?
03-24-2008, 06:40 PM #9
- Jun 2007
- Greenville,North Carolina
- 1,899
03-24-2008, 11:35 PM #10
03-25-2008, 12:17 AM #11
- Mar 2008
- liverpool ny
- 25
what about bob?
03-25-2008, 12:27 PM #12
I personally like how they fit on to the titan manifold.
But yes HeyBob, it can go on your exsisting manifold. But I dont like to lose one tool to gain another."Correct Installation is the Key"
.1 has killed more HX then Rush Limbaugh
What is your TESP?
03-25-2008, 07:21 PM #13
- Jun 2007
- 1,899
LOL!
