Results 14 to 20 of 20
    DC Metro Area (MD)
    I guess I used confusing terminology. When I mean over, I mean including (i.e. 2500 sq. ft. over 3 levels). Sorry for that confusion, but ~3500 sq. ft. for all three floors, including the basement, required around a 4-ton unit.
    Ok..
    So the OP has a larger home then you do, since his 3500, doesn't include the basement.
    Quote Originally Posted by craftsman101 View Post
    Is that 3500 sq ft with or without the basement . My 3350 sq ft, is without the basement...
    The exact same two houses oriented differently and landscaped differently could require two different sized systems. You'll need a load calc from someone that can measure the building themselves and evaluate your property using the load calc. or you can do the load calc. that the site has available. HVAC Calc
    DC Metro Area (MD)
    Ok..
    Correct, originally I didn't know he wasn't including the basement. So basically my situation should be ignored since my square footage without the basement is likely a bit less than 3000.
    SW FL
    Angry 2+2=4 So, Yes
    3350 sq FT. 2 story
    located in northwest indiana near chicago.
    I had a contractor out the house for a new ac to be installed.
    The size he came up with was a 4 ton.
    Does this sound like an adequately sized unit for the size home that I have???
    It all depends on Window Orientation / Area / SHGC
    and WHICH 4-ton?!
    Or is that 2 tons + 2 tons?
    Designer Dan
    chicago suburbs
    where in Indiana are you???
    FILL OUT YOUR PROFILE!!
    Chicago
    Iam in munster
