Results 1 to 13 of 17
    Oklahoma
    2nd Opinion - Rheem or Bryant?
    I live in the OKC area - 2000sf ranch w/a 9 yr old Goodman AC & Janitrol Gas Heater. The AC unit is always iffy - if it makes it thru the summer - the Gas furnace does OK. In getting bids - I can go with a 4ton 13 SEER builder's model Rheem (corsair/weatherking) that still uses the R22 or step up to the Rheem model using 410a Freon... or for about $800 more - I can go with a Bryant Evolution System (180ana048) 16 Seer 2speed AC & 94% HE (355aav060100) Var Speed 2 stage gas furnace. Comes complete with Evolution Programable Thermostat (systxbbuid01). I am leaning towards the Bryant system
    BTW - Thanks to all who participate in the forum. There aren't many sites where a "everyday" person can get some education and common sense approaches to a big purchase.
    You are leaning in a great direction.
    Use the search function on this site ,Infinity (the Carrier version) or Evolution,and you'll see what other homeowners think of this system.
    SW FL
    Quote Originally Posted by jb-Ok View Post
    In getting bids -
    (180ANA048) 16 Seer 2speed AC &
    Bryant
    Does a Heat pump make sense for the OKC area?
    Electric Rate?
    Gas Rate?
    Designer Dan
    Oklahoma
    I've thought a little about heat pumps - but am hesitant due to past problems. We avg electricity around 7.4 cents per kwh...gas around 8.306. The last twelve months (Feb to March) we used 17,897 kwh (hot summers) and 573 mcf gas.
    Kansas
    Go with the Bryant system. You can't really compare one systems builders grade combo with another ones top of the line. But if you did the Bryant is still the better choice. Its installer friendly, user friendly, and service friendly.
    Massachusetts
    Forget any manufacturer's bulders model. The savings is not worth it. YOu might as well send me your money and cut out the middle men, the results will be just as disappointing. I've attached a little note to help you choose a good company but I'd pick the Bryant Evolution system in a hearbeat over any other. In fact, I did. Ha! I've got one in my own home. Heat pump too that works down to 35*F then the oil unit takes over below that temp.
    Massachusetts
    Sorry. Forgot the attachement in the previous. Here ya go.
    Feb 2007
    Hands down the Bryant is a better deal for that little difference. The True humidiity control alone will pay for that in a short time.
    What's the budget? Comparing putting a King on a Janitrol furnace vs a 2 stage Evolution system is like comparing a Kia Rio with a S class Benz!
    If money is tight, the 13AJA48 is a nice unit for the bucks. Obviously needs a matching indoor coil to work right and be reliable. If you want & can spend it, the Evolution route has more comfort, more efficiency and many times the price.
    Since you aren't in a steamy area, if you wanna spend the bucks, I'd go for a Rheem Modulator and heat pump. Super heating comfort in cold weather, heat pump for cheap heat in mild weather. Available in 2 stage as well.
    SW FL
    Seems like
    Enormous energy hogs for just 2,000 S.F.
    Designer Dan
    Philadelphia, PA
    Make sure they are sizing the new equipment properly before deciding.
    And I agree with others. For the seemingly small difference you will be more comfortable with a properly sized Evolution system.
    Apr 2004
    Yeah something is wrong with that price difference unless either someone is giving it away or the other one is proud.
    Mar 2006
    The South
    jb-OK
    What is your electric rate?
