Results 1 to 13 of 14
    Furnace Flame sensor failures
    Folks,
    I'm new to this site. I'm not an HVAC professional. I need help. Can anyone tell me where I can find good reliable information (technical, statistical, other) on furnace flame sensor failure rates and the reason(s) for failures. Would the furnace manufactureres be good sources, is there a furnace manufacturers association out there I can contact, has anyone ever run across good articles on the subject? I'm open to everything. Thanks to anyone/everyone for help!
    Bob3
    Not really any good sites for that type of info.
    Most flame sensor failures are because of containates in the combustion air.
    Or improper burner set up.
    How many failures have you had.
    Rochester, NY
    I started a similar thread a while back. Hopefully this will help you:
    http://www.hvac-talk.com/vbb/showthread.php?t=132682
    Here are direct links to some helpful information:
    http://www.appliancemagazine.com/ae/...ne=214&first=1
    http://www.bradfordwhite.com/service..._corrosion.asp
    http://www.gastechnology.org/webroot...Page\11596.xml
    NOTE: Links are now fixed since original posting.
    leland nc
    there are seval reason for senser failor.
    te biggest reason is combustion sir contaminants as has been said
    gas purity is also playing a role
    flame impingment
    grounding of the unit
    burner ajustment
    and a few others
    the flame senser should be cleaned every year
    this is one reason the have your unit serviced
    Nov 2000
    Eastern PA
    Agreed;
    Combustion air contaminants such as anything that has chemically enhanced scents and/or the ammonia from cat boxes.
    Improper burning of fuel mix, especially for LP (propane) systems.
    Even oversized furnaces can contribute by having more cycles.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Apr 2004
    Most flame sensor failures are misdiagnosed when it comes to "changing the parts". A poor unit or board ground will cause them to lose flame signal on occasion, but the flame sensor itself, for a lack of a better description, is a metal rod with a ceramic mount. Odds are the sensors are not bad. Yes, the chemicals can cause them to corrode but gently polishing them is enough to bring them back. Unless the metal or ceramic is broken or burnt off, replacing it is an excersize in futilty.
    [QUOTE=docholiday;1804795]Most flame sensor failures are misdiagnosed when it comes to "changing the parts". A poor unit or board ground will cause them to lose flame signal on occasion, but the flame sensor itself, for a lack of a better description, is a metal rod with a ceramic mount. Odds are the sensors are not bad. Yes, the chemicals can cause them to corrode but gently polishing them is enough to bring them back. Unless the metal or ceramic is broken or burnt off, replacing it is an excersize in futilty.[/QUOT
    I have only had to replace 2 flame sensors in 15 yrs, one the ceramic was broken grounding out, the other I broke the cermaic...contaminates can be cleaned with sandpaper... what I'm finding lately on some inexspensive units is that the ignitors are sparking to the wrong point, instead of sparking to the pilot assmebly they ground to the burner, sometimes lighting, sometimes not..( PACKAGE UNITS)
    bob3 what is the unit doing?
    Snookered,
    Very helpful links. Thank you for taking the time to respond.
    bob
    All,
    Thanks for providing this insight. It has helped me to direct my research on the topic.
    Bob
    Bell,
    It's not my unit per se. I'm generally trying to understand the issues related to flame sensor failure to varying types of gas (or potentially air) quality on the functioning of a home furnaces' flame sensor. I'm trying to undertand if flame sensors are really sensitive to small impurities that exist over a very short time or if it's a realtively "insensitive" piece of equipment that is able to withstand a fair amount of "contamination" over time.
    Bob
    Grundy Co. IL
    Flame Sensors
    I don't know about the rest of you, but we come across flame sensors that are running on propane that end up being burned in half in a couple of years. But don't mention impurities in the gas, to the gas suppliers, they get very defensive. Anyone else see this?
    Apr 2004
    Then they werent set up right in the first place.
