Results 1 to 7 of 7
Thread: Rheem HP CU
    Jun 2007
    So Cal
    Rheem HP CU
    Last few condensing units I installed wouldn start till I grounded one side of the coil on the contactor
    Wonder how come I had to do this. Should I have done something different???
    Grottoes VA
    your not running a common wire.
    Jun 2007
    So Cal
    Yeah I did, honest.
    From the fan/coil
    Grottoes VA
    You have a bad roll of wire then.
    Jan 2006
    Hangin out with you losers
    Hmm
    Quote Originally Posted by karsthuntr View Post
    my guess
    I remember my first day,It was fun!
    Apr 2004
    well that or the time delay in the board (breaks the common) is either not fucitioning or you have not waited it out. grounding the common at the contactor just eliminated the LPS and timing functions including the soft shift.
    Could be wire, but I doubt it, otherwise the board would never power up.
    There are some lights on that board, what are they telling you?
    NW AR
    The last few? What did you do to fix the first one, leave it grounded to the cabinent?
