    Missouri
    Question Plastic or Metal registers best??
    Are plastic or metal registers the best? Does it matter?
    Wisconsin
    I don't think there's much of a difference. Most homes in my area use metal. And wood registers are becoming more popular with people who have hardwood floors. Just make sure the ducts and registers are the right size, that's more important than what the vent gills are made of. Some prefer one over the other, but I don't see much of a difference.
    Jul 2001
    Gold Coast of Connecticut
    Aluminum............spend the bucks
    http://www.hartandcooley.com/grd/all_grd.htm
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Plastic or wood are thicker material,so if replacing metal ones,the size likely needs to be increased,due to less open area to let the air flow thru.
    Baltimore MD and Ridgebury PA
    Quote Originally Posted by Jake1980 View Post
    I bought plastic initially and have not been happy with them. They just have not held up very well at all and I have started replacing them with metal. Of course, its possible that I just got a bad batch of plastic registers.
    Huntsville,AL
    increasing the size= increasing the 'boot', ie the transition piece from round to rectangular -- = $$
    and, use the same throw pattern -- [provided the original was ok]
