    Unhappy Thermocouple Failure
    Does anyone know what causes thermocuples to fail? I have replaced 3 themocouples within 6 months on a standing pilot Weil McLain boiler. Any insight is appreciated.
    Doug
    Aug 2001
    Alberta, Canada
    Thermocouple issues
    Cast Iron boiler burner compartments generate very high temps. In situations like yours, sometimes a stainless steel high heat resistant thermocouple may give you more longevity. Penn-Johnson make one, and are usually available at Heating Wholesale. Also check btu firing rate of boiler...make sure you' re not overfiring.
    Rochester, NY
    If it's a continuing pilot outage problem...
    Are you sure the T-couple is at fault? Have you checked the DC millivolt reading before replacing the T-couples?
    albany, new york
    Lightbulb thermocouple
    make sure no part of thermocouple is touching anything metal.
    Improper set up.
    Nov 2001
    east kansas
    Where in Alsaska are you?
    I was at Ft. Greely for a while. Spent a lot of weekends in Fairbanks.
    Beware of advice given by some guy on the Internet.
