    New Lennox system
    I've received two quotes for a new Lennox system (4 ton, XC21-048-230 condensor, coil-Aspen CE60D44210R-051(C) the same on both. However, the furnace differs from a G60UHV-60V-90 and a G60UHV-60C-090/5 ton. What's the difference in these furnaces? The Lennox web-site does not indicate.
    burlington county n.j.
    G60UHV-60v does not exist must be a typo. proper # is G60UHV-60C
    Jun 2007
    Central, FL
    If I'm not mistaken one has a Variable speed fan blower, the other dosen't recheck both model # to be safe!
    http://www.lennox.com/products/list.asp?type=2
    WARNING:IF YOU DON'T KNOW THEN DON'T DO, SO THOSE WHO KNOW WHAT YOU DIDN'T KNOW DON'T END UP UNDOING WHAT YOU DID SO IT COULD GET DONE RIGHT!
    Washington State
    on what t527ed said.
    Sounds like exactly the same equipment, the 60V is a typo.
    Quote Originally Posted by AcDOCnTRAINIG View Post
    G60UHV makes both of them v drive units, 60 is blower size, c is cabinet size.
    v is not a cabinet size made and c is the only cabinet size you can get in this size blower/heater combination.
