getting the right size vacuum pump
What would be a good cfm of vacuum pump to have. I do only resi work. What are the best brands and why? Thanks!!
I recommend the YJ 1.5, because its the best setup I have ever used.
"Correct Installation is the Key"
.1 has killed more HX then Rush Limbaugh
What is your TESP?
we use 5 cfm and 6 cfm pumps
Well, that explains alot
What is your TESP?
I have a 3 cfm dual stage I think it's a bit to big for the systems I have. I would try and get the smallest dual stage possible.
i use what they give me
http://robinair.com/product-new/deta...=1061&catid=11
This thread may help you:
http://www.hvac-talk.com/vbb/showthread.php?t=159232
Go to the JB website (jbind.com). There is plenty of literature available on selecting a vacuum pump that is right for you. Try to find a distributor of JB, they may let you test out some vacuum pumps. I'm currently testing a 7 cfm and a 3 cfm.
The most simple way to sum things up is that cfm doesn't mean a whole lot. Once the system reaches a vacuum, which is usually less than a couple minutes on small systems, a 1.5 cfm to a 10 cfm work pretty much the same.
They work the same. But the larger one will still be drawing quicker. The primary is still bigger.
If you draw too quick, you could form ice crystals.
I personally use a 6 cfm Yellow Jacket and have a never had a problem with it very easy to use and quick
I use a 6 also.
Have seen a lot of guys use 7's.
No need for a large vac, for small resi stuff though.
All I work pon is small residential sized systems. I have to play with the ballast within a few minutes to keep it around the 3000-5000 microns.....I'd rather it take a little longer to make sure it's not forming crystals instead of boiling off.
So a 5 or 6 cfm YJ, robinair, or JB pump would be the best way to go. And always dual stage...right?
If your not going to work on anything bigger the 20 ton, a 3 CFM works good.
But a 5 or 6 will do also.
- You may not post replies
- You may not edit your posts
Forum Rules
