Results 1 to 7 of 7
    Windsor area Ontario Canada
    Noma t-stat junk
    Has anyone ran into this problem? i have seen it a few times... people with 30 or 40 year old olsen or clare heckla low boys changing from a mechanical t-stat to a cheapo digital programmable especially the NOMA brand they sell at canadian tire or wal mart, anyways what happens is they put these stats in themselves and a few weeks later their furnace will not work, it works for a bit with these stats then all of a sudden no heat, i go in change the stat to a mechanical or a honeywell programmable and it works fine, can anyone tell me the reason for this?
    My first guess would be a cheapo t-stat.
    Afton, VA / Khorat, Thailand
    Yea, junk is junk, wherever you buy it.
    Midnight Sun Astrophotography
    Northeast Ohio
    Some digital thermostats don't use relays to control the system. They use other electronic components that must not be compatible with the older system's circuits.
    Jun 2001
    Louisville, KY
    Triacs on the cheapies can't handle the current flow of the old beasts.
    Northeast Ohio
    Quote Originally Posted by jrbenny View Post
    Exactly.
    Rochester, NY
    In most applications an isolation relay can be installed to solve the problem...
    I really can't go much further due to site rules.
