Results 14 to 24 of 24
    If she looks anything like you I hope you have a fat wallet
    N.E. Ok.
    Quote Originally Posted by air2spare View Post
    I was thinking if she looked anything like him there would be plenty of room for stamps on her forehead
    Don't over size the mini.
    Leave it on, during thos times the central is operating, the mini won't, So you won't be wasting elelctric.
    Toledo, Ohio, United States
    Man these newbie's are rough on Twilli. If you don't want Twilli's ex then mini split may be the way to go
    No Heat No Cool You need Action Fast
    Quote Originally Posted by twilli3967 View Post
    How much heat load does she add?
    fletch
    N.E. Ok.
    Quote Originally Posted by irwin_fletcher View Post
    fletch
    twilli did a man.j on the trailer but i bet he didn't add the extra btu's for the ex.
    thats why shes an ex, the coleman couldn't keep up.
    now, now....the newbies like Twilli
    Attachment 6304
    Jan 2002
    Ft.Worth,Tx
    Quote Originally Posted by Billss View Post
    2200 sq ft, 1 story home in Dallas, TX. Built in 1950's. 5 ton AC, Janitrol 10 SEER. New American Standard variable speed, 2 stage 80% furnace. We've had a small window AC that we (empty nesters) have used past 2-3 summers for bedroom at night, setting thermostat on main AC at 85. Both of us work during the day, when we also have the AC set at 85. Thus, AC is on for a couple of hours in am and then in the evening. (In spring and fall we use whole house attic fan to pull in outside cool air.)
    It seems to make a lot of sense not to cool the entire house at night, but the current arrangement just is not satisfactory. The window AC is noisy and we're concerned about safety (window faces back yard, making easy entry for a burglar).
    We have a very small 1/2 bath off of our bedroom, with a window that is too small (20" w X 36" high for any window AC unit that I've ever seen.
    Are there other reasonably priced, efficient options we could consider to cool just our bedroom at night?
    Why not spend a little cash and replace your Janitrol with better unit and zone the home with a system that cuts air off to other area's at night and give bedroom more air while sleeping.
    AS~Std Variable drive
    Coil/TXV
    Condenser 14.0 Seer
    2 Zone system
    Cut your electric bill down and save.$$$
    What part of Dallas?
    'Life begins with the journey each day'
    zones with a single AC?
    Didn't know that it was possible to have two zones using just a single AC unit?
    you could even go three....wouldn't recommend any more than that
    If given proper consideration size, 4 or more zones is not a problem.
    Just gets expensive to install.
    I have some single stage heat pumps with VS air handlers, that have 5 zones.
    Used EWC for the zoning.
    True, I used a combination of bypass, and a dump zone into a hallway.
