Results 1 to 13 of 20
    Mar 2006
    DFW
    Where to buy a Testo 523 refer analyzer?
    Eat a slice of Humble Pie.
    OK price.
    Was looking at their Testo 435 kits. They have amazingly bad documentation of exactly what each kit is for, and what is included with it, which is CRITICAL information.
    Someone from Testo needs to get with these folks and straighten them out...
    Mar 2006
    eastern Ontario
    I suggest you look at all options before you purchase testo. I have owned 4 different sets in the past 2 years. All sets have leaked out of the service valves. 2 sets have been returned for service or replacement. The last 2 are leaking and will be returned for credit. Very dissappointing product especially with our short cooling season......Just called my supplier yesterday to give the serial number and date code and refrigerant oil leaked out onto my desk.
    Attitude is the difference between and ordeal or adventure
    johnstone supply sells'em for 499 here. (testo 523)
    they also have the kit with the printer if you want that option as well.
    i just ordered the yellow jacket digital set friday for 649
    http://www.youtube.com/watch?v=nFl0n...ture=endscreen
    Mar 2006
    DFW
    A teacher at school has the yellow jackets and said that the temperature probe that plugs into the gauges is way off. Now I have never used the yellow jacket gauges so I dont know if he just had a bad set or what, but it definitely made me hold off on buying a set. Now Im hearing that the Testo's leak. Guess I will have to make it through another summer with my analog gauges.
    Greenwood IN
    Quote Originally Posted by rogerk View Post
    Have the instructor talk to Digi-Cool about that temp probe, I am sure Doug would like to know if it is way off. He's kinda picky like that
    There was a recall on the Testo's, something about the valves, contact Testo directly and they should be able to point you in the right direction.
    Reality is merely an illusion, albeit a very persistent one.
    -Albert Einstein
    Jan 2005
    Akron
    There is no problems with leaking on the new generation Testo 523.
    The first generation of the testo 523 did leak if the handles were over tightened. (Which was not hard to do.) The replacement handle has a stop installed to prevent overtightening. When the leaking sets were sent into service, they were replaced with brand new sets so the leaking sets could be analyzed.(At the time we did not know why this was happening.) The replacement sets had the same problem, and hence leaked again. If you send them in for service now, the handles will be replaced with a new designed handle and the problem will no longer persist. We are sorry for the inconvenience, however they do carry a full two year warranty, and are well worth repairing.
    The new 523 has had no issues with leaking at the valve handles, and is a rock solid instrument. The larger display and more intuitive operation make the instrument much easier to use.
    Jim Bergmann
    HVACR Technical Specialist
    Tecto Inc.
    JLB- Co Owner TruTech Tools Inc.
    Fuquay Varina, N.C.
    Smile Where to buy a Testo 523 refer analyzer
    I found a price at amazon.com for $349.00 That I am seriously considering.
    Quote Originally Posted by sparky05 View Post
    you better do it now!!!! and get me one while your at it
    i just got mine today and only was able to use them on three systems. and all my readings on the temp probe where right inline with my DMM and pipe clamp
    as far as the testo leaking. sometimes you cannot believe everything you hear. do we know how that guy took care of his gauges?? lot of people really crank down on gauges, and thats a huge mistake!!
    i just got my YJ set ,and in a couple months i will get the teto set and see for myself shich ones i like. i have heard numerous people say the YJ's are made by digi-cool. don't know how true it is, but there are alot of similarities
    Make sure which one it is before you buy.
    There is an "old style" 523 and a "new style" 523 that are very different products.
    Southern Ca, Elkton Md
    Yup, really make sure with that price!
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    Its true, Digi-Cool is the manufacture, has a different face plate and rubber.
    What is your TESP?
