    Braintree, Ma.
    What's your audience?
    Is this forum for any specific type of HVAC system? I have a forced hot water oil fired boiler with tankless water heater. The house has 3 zones each with it's own circulating pump. It was installed and maintained by a local oil dealer for over 30 years. The only DIY thing I did was add a wireless thermostat because one of the zones did not heat the rooms (kitchen, dining, living) ok with one thermostat position. I move it around with me so it's 70 wherever I am.
    Is this the type of system that your PROs have experience with?
    Thanks, Retired MSEE
    leland nc
    what are your concerns with the system
    Ok, whats your main question.
    Many of us know hydronics also.
    MI
    He doesn't have a question, he has a point!
    Braintree, Ma.
    My point is that I was afraid that your members were only interested in gas or steam. I found this out only after a while on other HVAC forums. I have been messaging here under the Title "Weil-Mclain dead"
    leland nc
    Quote Originally Posted by olrob View Post
    I was following that tread for a while and it seemed to me you were diven a lot of good options for your problem
    I stopped servicing oil some years ago because i didnt like smelling like oil all the time. I like oil heat better then gas and feel if it is set up properly it can be cheaper in the long run
    The company i get my oil from has said it is hard to believe that i only use about 8 to ten gallons a week in a 1700sq ft house
    total cost to heat this season so far has been 550
    there are a lot of oil techs on this board and a lot of hydronic techs also
