Results 1 to 13 of 18
Thread: R22 to R134a
    Valdosta Ga
    Confused R22 to R134a
    Cost of R22 is getting out of the area where I am comfortable with it r-134 now is less than half the cost of r-22.
    Hot Shot and R-407 still not ball park so can a r-22 be upgraded to R134a?
    Austin, TX
    Big pressure difference, not sure the compressor can handle it. Too
    many items to change out.
    Nov 2007
    I am unsure myself
    Anything can be done if you change out enough parts.
    Florida
    R-134a is the replacement for r-12, not r-22......you can put in whatever refrigerant you want but the system is only designed for one type usually, and a drop-in will be a close match. You go changing refrigerants and a nightmare will be created....
    Valdosta Ga
    Would have to swap oil for a R407 upgrade anyway whats the diff. besides changing metering devices.
    Nov 2007
    I am unsure myself
    All your pressure controls and safeties etc would have to be changed as 134a runs at considerably lower pressures. Add in compressors metering devices oil would also hav to be changed getting pretty close to a new unit. Stick with 407c or there is a drop in by dupont r422d we have been trying out haven't had any problems yet but time will tell.
    Valdosta Ga
    Thanks for info on R422d well check it out
    Houston, Tx
    Assuming you get it working, both R-134a and 422b will give you a capacity reduction -(20% for R 422B)
    Valdosta Ga
    That would be right on the capcity reduction but there are alot of older overside systems here that are prime canidates.
    Quote Originally Posted by dlupkes View Post
    422D??
    For low temp it is more 14% efficient and for medium temp it has the same performance as R-22 according to DuPont.
    Valdosta Ga
    I guess if you want R422d your going to have to get it from a new Distributer because the older Distributer's have stocked up on R-22
    an will not sell R422d till R-22 is gone.
    Nov 2007
    I am unsure myself
    Find a new distributer most don't stock it but we have not had any problems getting it.
