Results 1 to 11 of 11
    does Lennox make a double stack?
    this is a Lennox mounted on top of another Lennox...in Marshalltown, Iowa...the home of Dave Lennox!
    i don't see the pic
    Rochester, MN
    Photo is awful small!
    Howell, Michigan
    Who in their right mind would do that?
    I get no picture either
    Howell, Michigan
    I did earlier..........but none now.
    Afton, VA / Khorat, Thailand
    Those wacky Iowans.....
    Maybe it's a doghouse, I've seen 'em made from TV's.
    Midnight Sun Astrophotography
    Now the postage stamp is back!
    Had one just like it here. Condo complex. Someone set their new Jani#$!@ on the old HS-6 just like here. Later we changed them to an add on HP. Tried setting it on top of the Jani but it was hard to reach for service so we took them both out and used a pad & pump ups
    los angeles
    Where's the beef?
    Wisconsin
    That's called recycling. When you have to replace your system, you just use the old condensor for a pad. Especially in areas where there is high snow levels, and you are installing a Heat Pump. That way it keeps the condensor above snow level.
    Quote Originally Posted by mayguy View Post
    took the pic with my cell phone while in the drive thru...i tried to blow it up but it got really pixilated.
    good luck.
