    Confused Filter Clearance
    I'm looking at suspending my a/c air handler from the ceiling (vertically) in a conditioned space. In this way I won't need a return duct. The return air can enter the unit from the bottom, and I can use the factory mounted filter slot.
    How much clearance will I need below the unit for good air flow. Space is tight.
    west virginia
    is there not enough room to install the unit horizontally above the ceiling? most units are multi-position and are easily converted to horizontal left or right
    Jun 2001
    DFW
    For good airflow
    take the smaller dimenstion from the filter size and divide by two.
    for example, if the filter size is 20x24
    then, you need 20" / 2 = 10" minimum clearance between the floor and the filter.
    This assumes that there are NO other airflow restrictions to the filter.
    burlington county n.j.
    gonna be a noisy one..........
    Quote Originally Posted by t527ed View Post
    definately
    do it right the first time!
    Florida
    Alot depends on how you're "hanging" it. Is it boxed in(airflow on one side only), is it hanging in the middle of your living room(4 sides free)? Each situation is different. Got pics?
