Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    Any Frigidaire AC experts here
    I had a new 14 seer Heat pump and variable speed furnace installed and am wondering if my system has dehumidificaiton feature. I can provide the furnace # and heat pump # if needeed? I am using a Vision Pro thermostat and do not see this feature on my thermostat.
    Post all the model numbers ,including the stat.,someone here will likely know.
    I hope it does have dehumidification control,as you went with a larger system,without a load calculation.
    http://www.hvac-talk.com/vbb/showthread.php?t=158774
    The 8321 has cool to dehumidify.
    It doesn't have the ability to slow the blower though.
    The air handlers have had this capability for a while, the gas furnaces are just now adding this feature -- assuming you mean the dehumidify on demand that the Vision Pro IAQ is capable of.
    Somewhere in the midwest
    The blower has the ability to slow to 75% of the selected cooling cfm for maximum dehuhidification on the furnaces and A/H. A qualified servicer would know how to wire in a humidistat.
    Sound installation practices is the key to success. Equipment is only as good as the person installing it.
    If I can't fix it, it ain't broke.
    Chicago, IL
    i installed one 2-3 years ago (the old split manifold style) and it had Dehum terminals on the board where you adjust the CFM
    I have 2 neighbors in my neighborhood who had the load calcs done and they each have a 4 ton system(Same house as me. Facing the same direction and the closest one is one block over). I tried to get one done, but i was freezing with no heat pump in winter at the time. My wife was not happy and i lost $1000 in saltwater aquarium life from my system not working and was going to loose more. I had to make the best decision at the time and i feel i made the correct one. The other 2 techs that came over were horrible.
    This tech added another return and that has made the house cool and heat more evenly since I have had the new system.
    Their are some minor gripes with my install but I won't get into that.
    I will get my model #'s tonight and I am using a Vision Pro and iwll get the model #.
    Furnace Model # B5VM-T49K-C and Heat Pump Model FT5BD-048K.
    Thermostat is a Vision Pro Model # TH8320U1008
    That stat doesn't do cool to dehumidify.
    The YTH9421(known as the IAQ stat), would get you abetter use of your system.
    So would the Th8321. Not as good as the IAQ though.
    Thanks I figured that out last night after researching it a bit more. I will get the correct one.
    When they come back to install the stat,be sure to ask what they set the air handler to,as far as cfms(air flow),I'd recommend 350 cfms per ton ,for Florida.
    Dash.
    Since the IAQ can keep the blower slowed down the entire cooling call. Which would be less then 350 per tom for many units. Do you still recomend 350 per ton for Florida for systems using the IAQ.
    Naples, Fl
    I'm no Dash but I'll say that the 350 proves optimum. With the Southwest Florida summertime due point average being 74 degrees the less run time at the reduced discharge temps the better. The 350 per ton still provides improved dehumidification which reduces the amount of cool to dehumidify operatioin and in my book thats a good thing.
