Results 1 to 7 of 7
Thread: pressure switch
    california
    pressure switch
    How often does a pressure switch for an inducer draft motor actually fail. What is typically the underlying problem
    West Valley City, UT
    I've replaced two this year (so far), both were about 3-ish years old.
    california
    The furnace is a 3 year old tappan . The tech that came out said he could not get a pressure switch for a tappan .
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by jmiles View Post
    they can last for 1 day
    they can last for 1 year
    they can last for 10 years
    it all depends on a variety of circumstances
    Dec 2006
    Middle Tennessee
    thats a sad day when you cant get a part for a 3 year old system
    seems like he was not looking good enough!
    Lancaster PA
    3 year old Tappan. Its still under part warranty.
    Look in the phone book for Tappan dealers, they will have it, or be able to get it.
    Pressure switches don't go bad often, But are quit often condemned for doing their job.
    Oct 2005
    Smile
    pressure swithes have a rubber diaphram inside them. eventually they will stretch enough that they don't make the circuit. They can also become erratic when there are minor obstructions in the orifice at the furnace,inside the tube etc.If the inducer doesn't get up to speed, the pressure switch also will become erratic. I've seen numerous ones changed, only to find out it had a different problem. You need to verify the failure mechanically and electrically.
