Results 1 to 7 of 7
    simple; physical size question??
    I have a trane xl16i and it is very large. a 3ton if i remember correctly. why are some other units i see so much smaller. like my next door neighbours ruud unit???
    Naples, Fl
    coil area required for higher efficiency for one thing.
    Lancaster PA
    Becuse if it was as small as you neighbours, you'd think you paid too much for it. J/K
    As above, coil size needed for efficiency.
    South Central Oklahoma
    It is a manufacturing thing. This way different brand units will not all look rectangular or square or round. Depending on SEER rating they may have smaller coil surface compared to a larger one.
    Afton, VA / Khorat, Thailand
    Yes, higher SEER units usually physically larger.
    Midnight Sun Astrophotography
    thanks guys!!!
    Most A-S/Trane units are very large, I think the Spine Fin coil has to do with that. The old clunker recip is big which doesn't help sizing or weight.
    But efficiency does have a lot to do with it. A 16 SEER Ruud is good sized too!
