Results 1 to 11 of 11
Thread: ductless wtf?
    ductless wtf?
    saw this at a bank in brooklyn the other.....
    Massachusetts
    So I guess they're cooling the hot money in the vault and warming up the lobby at the same time. Pretty ingenious!!
    burlington county n.j.
    one rooms to cold, one rooms to hot.......... i got a solution for that..........
    Afton, VA / Khorat, Thailand
    It would probably get stolen if it was outside.....
    next morning just 2 copper lines up on blocks.
    Midnight Sun Astrophotography
    Jan 2006
    Powell River, BC, Canada
    It's for all that COLD hard cash!
    Where are you? Are you done yet? I got ONE more call for you.....
    St.Paul, MN
    Isn't that called heat reclaim.
    Remember, some poor fool has to work on what you install someday, and it might even be you.
    Madison, Wisconsin
    Keeps it from getting all dirty this way
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Oct 2006
    In a freezer or in an attic somewhere
    Cool
    It looks like a new install. There is no electrical hooked up and the cond. is still on a pallet.
    If that is were it is going they'll soon find out their wrong doing.
    Probably didn't have a way to drill through the wall to install correctly, but it doesn't matter they already wasted the charge in the line set. Probably don't have a vacume to boot.
    What a shame.
    Also I wonder if they ordered the low ambient kit for that unit.
    Ct
    Maybe it's a heat pump, running in heat mode, and they actually wanted cooling. Figuring it must be installed backwards, so they switched the evap and cond.
    Only problem is they need to walk outside with the remote to turn on the AC.
    Mar 2006
    ductless = no ducts... i dont see any ducts
    May 2005
    Grand Rapids, MI
    I have seen that before with warehouses with mezanines. A good example is Johnstone Supply did it when they added a training room upstairs here in town. It was the easiest solution for them. The heat pump units are in the warehouse on the second story. The air handlers are in each training room. They seem to work well. It would not be my first choice (and no we weren't the contractor that did the work). But it works.
